Zum Hauptinhalt wechseln
Samsung ML2510 Motor Replacement
Was du brauchst
  1. Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 1 von 3 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 2 von 3 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 3 von 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Motor Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Motor Replacement: Schritt 3, Bild 1 von 3 Samsung ML2510 Motor Replacement: Schritt 3, Bild 2 von 3 Samsung ML2510 Motor Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Motor Replacement, Motor: Schritt 4, Bild 1 von 3 Samsung ML2510 Motor Replacement, Motor: Schritt 4, Bild 2 von 3 Samsung ML2510 Motor Replacement, Motor: Schritt 4, Bild 3 von 3
    • Remove the front panel by gently moving the holes on the panel, one at a time, from the pegs attached to the main body of the printer.
  5. Samsung ML2510 Motor Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
  6. Samsung ML2510 Motor Replacement: Schritt 6, Bild 1 von 3 Samsung ML2510 Motor Replacement: Schritt 6, Bild 2 von 3 Samsung ML2510 Motor Replacement: Schritt 6, Bild 3 von 3
    • Use plastic opening tool to gently lift one side of the top panel from its peg.
    • Repeat the first process for the other side.
    • Lift the top panel from the front of the printer to remove it entirely.
  7. Samsung ML2510 Motor Replacement: Schritt 7, Bild 1 von 3 Samsung ML2510 Motor Replacement: Schritt 7, Bild 2 von 3 Samsung ML2510 Motor Replacement: Schritt 7, Bild 3 von 3
    • Lift the left side panel up from the raised stops.
    • Gently rotate the panel, as indicated in the picture, to remove the panel entirely.
  8. Samsung ML2510 Motor Replacement: Schritt 8, Bild 1 von 3 Samsung ML2510 Motor Replacement: Schritt 8, Bild 2 von 3 Samsung ML2510 Motor Replacement: Schritt 8, Bild 3 von 3
    • Use Phillips #2 screwdriver to remove the five, 1", Phillips, PH#2 screws on the side metal panel.
    • Remove the two, 1", Phillips, PH#2 screws on the back of the printer.
    • Flip over the metal panel to reveal the gear mechanism.
  9. Samsung ML2510 Motor Replacement: Schritt 9, Bild 1 von 3 Samsung ML2510 Motor Replacement: Schritt 9, Bild 2 von 3 Samsung ML2510 Motor Replacement: Schritt 9, Bild 3 von 3
    • Remove the cable attached to the motor.
    • The entire panel can be removed from the rest of the printer.
    • Use a Phillips #2 screwdriver to remove the motor from the panel by removing the two, 1", Phillips, PH#2 screws.
    • Replace the motor and reassemble the printer by following the instructions in reverse order.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
bbaustin
268 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-18, Regan Fall 2011 Mitglied von Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 4,750
