Zum Hauptinhalt wechseln
Samsung ML2510 Power Button Replacement
Was du brauchst
  1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 1 von 3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 2 von 3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 3 von 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Power Button Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Power Button Replacement: Schritt 3, Bild 1 von 3 Samsung ML2510 Power Button Replacement: Schritt 3, Bild 2 von 3 Samsung ML2510 Power Button Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Power Button Replacement, Power Button: Schritt 4, Bild 1 von 3 Samsung ML2510 Power Button Replacement, Power Button: Schritt 4, Bild 2 von 3 Samsung ML2510 Power Button Replacement, Power Button: Schritt 4, Bild 3 von 3
    • Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
  5. Samsung ML2510 Power Button Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove both 1" screws on the front face of the printer.
  6. Samsung ML2510 Power Button Replacement: Schritt 6, Bild 1 von 3 Samsung ML2510 Power Button Replacement: Schritt 6, Bild 2 von 3 Samsung ML2510 Power Button Replacement: Schritt 6, Bild 3 von 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the last step to free the opposite side of the top panel.
    • Lift the top panel from the front to remove it entirely.
    • Turn over the top panel to reveal the button on the underside of the panel.
  7. Samsung ML2510 Power Button Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove both 1" screws that secure the button to the underside of the top panel.
  8. Samsung ML2510 Power Button Replacement: Schritt 8, Bild 1 von 2 Samsung ML2510 Power Button Replacement: Schritt 8, Bild 2 von 2
    • Remove the clear plastic piece and the orange button from the panel.
    • Remove the orange button and the spring from the clear plastic holder.
    • Replace the button and reassemble the printer following the directions in reverse order.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
bbaustin
268 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-18, Regan Fall 2011 Mitglied von Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 3,160
