Zum Hauptinhalt wechseln
Samsung ML2510 Rear Cooling Fan Replacement
Was du brauchst
  1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 1 von 3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 2 von 3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: Schritt 1, Bild 3 von 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Rear Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Rear Cooling Fan Replacement: Schritt 3, Bild 1 von 3 Samsung ML2510 Rear Cooling Fan Replacement: Schritt 3, Bild 2 von 3 Samsung ML2510 Rear Cooling Fan Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: Schritt 4, Bild 1 von 2 Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: Schritt 4, Bild 2 von 2
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
  5. Samsung ML2510 Rear Cooling Fan Replacement: Schritt 5, Bild 1 von 1
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
Ziellinie
bbaustin
268 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-18, Regan Fall 2011 Mitglied von Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 3,363
