Zum Hauptinhalt wechseln
Samsung MV900F Flash Bulb Assembly Replacement
Was du brauchst
  1. Samsung MV900F Flash Bulb Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 2, Bild 1 von 1
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Flash Bulb Assembly Replacement, Screen: Schritt 4, Bild 1 von 2 Samsung MV900F Flash Bulb Assembly Replacement, Screen: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 5, Bild 1 von 2 Samsung MV900F Flash Bulb Assembly Replacement: Schritt 5, Bild 2 von 2
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 7, Bild 1 von 1
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 8, Bild 1 von 1
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the old screen.
  10. Samsung MV900F Flash Bulb Assembly Replacement, Lens Assembly: Schritt 10, Bild 1 von 1
    • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
  11. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 11, Bild 1 von 1
    • Use the plastic opening tool to remove the silver metal lens cover.
  12. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 12, Bild 1 von 1
    Kaufen
    • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
  13. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 13, Bild 1 von 1
    • From the front of the camera, push the lens through the back of the camer.a
  14. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 14, Bild 1 von 2 Samsung MV900F Flash Bulb Assembly Replacement: Schritt 14, Bild 2 von 2
    • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
  15. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 15, Bild 1 von 2 Samsung MV900F Flash Bulb Assembly Replacement: Schritt 15, Bild 2 von 2
    • Remove the lens assembly from the camera.
  16. Samsung MV900F Flash Bulb Assembly Replacement, Flash Bulb Assembly: Schritt 16, Bild 1 von 1
    • Remove the 2.381 mm screw that is holding the copper to the control board with a Phillips #00 screw driver.
  17. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 17, Bild 1 von 1
    Kaufen
    • Use tweezers to pull copper connector from the control board.
  18. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 18, Bild 1 von 1
    • Use the plastic opening tool to pry the control board up, thus allowing the flash bulb assembly to be removed.
  19. Samsung MV900F Flash Bulb Assembly Replacement: Schritt 19, Bild 1 von 1
    • Beginning with the battery on the side, gently pull upwards to remove the entire flash bulb assembly.
Abschluss
Sam Houston State, Team 13-2, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 13-2, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G2
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 297
