Was du brauchst
Slide the lock towards the middle of the camera, in the same direction of the arrow.
Use tweezers to remove the four rubber screw covers.
Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
Use plastic opening tool to disconnect screen connector from the control board.
Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
Eine weitere Person hat diese Anleitung absolviert.
