Einleitung
This guide will demonstrate eight steps on how to replace the flip screen on a Samsung MV900F Smart Camera.
Was du brauchst
Slide the lock towards the middle of the camera, in the same direction of the arrow.
Use tweezers to remove the four rubber screw covers.
Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
Use plastic opening tool to disconnect screen connector from the control board.
To reassemble your device, follow these steps in reverse order.
Ein Kommentar
Anyone an Idea where I can buy a cheap new display for that cam?
