Zum Hauptinhalt wechseln
Samsung Mythic SGH-a897 Camera Replacement
Was du brauchst
  1. Samsung Mythic SGH-a897 Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Camera Replacement: Schritt 2, Bild 1 von 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Camera Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Camera Replacement: Schritt 4, Bild 1 von 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Camera Replacement, Camera: Schritt 5, Bild 1 von 2 Samsung Mythic SGH-a897 Camera Replacement, Camera: Schritt 5, Bild 2 von 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
Abschluss
Morgan Yost
46 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-1, Regan Spring 2013 Mitglied von Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 278
