Zum Hauptinhalt wechseln
Samsung Mythic SGH-a897 Ear Speaker Replacement
Was du brauchst
  1. Samsung Mythic SGH-a897 Ear Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 2, Bild 1 von 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Ear Speaker Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Ear Speaker Replacement, Camera: Schritt 5, Bild 1 von 2 Samsung Mythic SGH-a897 Ear Speaker Replacement, Camera: Schritt 5, Bild 2 von 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 Ear Speaker Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 7, Bild 1 von 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 7, Bild 2 von 2
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 8, Bild 1 von 1
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 9, Bild 1 von 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 9, Bild 2 von 2
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 10, Bild 1 von 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 10, Bild 2 von 2
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 11, Bild 1 von 1
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 12, Bild 1 von 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 12, Bild 2 von 2
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 13, Bild 1 von 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: Schritt 13, Bild 2 von 2
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
  14. Samsung Mythic SGH-a897 Ear Speaker Replacement, Daughterboard: Schritt 14, Bild 1 von 2 Samsung Mythic SGH-a897 Ear Speaker Replacement, Daughterboard: Schritt 14, Bild 2 von 2
    • Use the tweezers to unclip the connector.
    • Remove the daughterboard.
  15. Samsung Mythic SGH-a897 Ear Speaker Replacement, Ear Speaker: Schritt 15, Bild 1 von 1
    • Use tweezers to unclip the silver connector.
    • Then put pressure on the black latch which is circled to release the speaker.
Abschluss
Collin Gordon
45 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 17-1, Regan Spring 2013 Mitglied von Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 231
