Einleitung
This guide will show you how to replace a faulty speaker.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
    • Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
  2. Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
    • Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove six 5 mm Phillips #0 screws from the back of the phone.
    • Remove six 5 mm Phillips #0 screws from the back of the phone.
  5. Insert a plastic opening tool into the seam between the back case and the rest of the phone.
    • Insert a plastic opening tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back from the phone.
  6. Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out. Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
    • Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Abschluss
Morgan Yost
46 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-1, Regan Spring 2013 Mitglied von Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Mitglieder
18 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 140
