Zum Hauptinhalt wechseln
Samsung NP N310 HAA2US Cooling Fan Replacement
Was du brauchst
  1. Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Cooling Fan Replacement, Back Panel: Schritt 2, Bild 1 von 2 Samsung NP N310 HAA2US Cooling Fan Replacement, Back Panel: Schritt 2, Bild 2 von 2
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Cooling Fan Replacement: Schritt 3, Bild 1 von 3 Samsung NP N310 HAA2US Cooling Fan Replacement: Schritt 3, Bild 2 von 3 Samsung NP N310 HAA2US Cooling Fan Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
  4. Samsung NP N310 HAA2US Cooling Fan Replacement, Cooling Fan: Schritt 4, Bild 1 von 2 Samsung NP N310 HAA2US Cooling Fan Replacement, Cooling Fan: Schritt 4, Bild 2 von 2
    • Remove the 3 Phillips 4.5mm silver screws on the fan. Use a size 1 Phillips screwdriver
    • Remove the 1 Phillips 8mm black screw on the fan. Use a size 1 Phillips screwdriver.
  5. Samsung NP N310 HAA2US Cooling Fan Replacement: Schritt 5, Bild 1 von 2 Samsung NP N310 HAA2US Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Lift the fan up, and remove the yellow tape.
    • Unplug the fan cable.
Abschluss
Amir Afridi
626 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 4-1, Passmore Fall 2016 Mitglied von USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 422
