Zum Hauptinhalt wechseln
Samsung NP-130-JA01US Keyboard Replacement
Was du brauchst
  1. Samsung NP-130-JA01US Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Keyboard Replacement: Schritt 2, Bild 1 von 2 Samsung NP-130-JA01US Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Samsung NP-130-JA01US Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Keyboard Replacement: Schritt 5, Bild 1 von 3 Samsung NP-130-JA01US Keyboard Replacement: Schritt 5, Bild 2 von 3 Samsung NP-130-JA01US Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Flip the computer and open the front cover so that the screen is looking at you.
    • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
    • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
  6. Samsung NP-130-JA01US Keyboard Replacement: Schritt 6, Bild 1 von 3 Samsung NP-130-JA01US Keyboard Replacement: Schritt 6, Bild 2 von 3 Samsung NP-130-JA01US Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Flip the keyboard over.
    • Notice the lock mechanism (marked in red) that holds the cables to the computer.
    • With your fingers, flip the mechanism over before pulling the cables out.
    • Second picture shows the unlocked position.
    • Carefully pull the cables out of the computer.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 9-6, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 330
