Einleitung
The screen is one of the more difficult parts of this laptop to replace, but it also is exposed and fairly fragile. Replacing the screen rather than the laptop could make an accidental drop into a much smaller problem.
Was du brauchst
Take out the four 4.5mm Phillips #0 screws located at the corners of the screen.
Unscrew each of the four 6.5mm Phillips #0 screws securing the screen to the case.
Using the black spudger tool and your fingertip, gently push on the ends of the ribbon cable to pop it out of the socket.
Eine weitere Person hat diese Anleitung absolviert.
