Zum Hauptinhalt wechseln
Samsung NP-N145-JP02US Fan Replacement
Was du brauchst
  1. Samsung NP-N145-JP02US Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • Before starting the replacement, turn off the device sure and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the back of the device from the main frame by unscrewing the 14 4.5 mm screws using a Phillips #0 screwdriver.
    • Once all screws are out, pry open the back cover piece of the device using a plastic opening tool.
  3. Samsung NP-N145-JP02US Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 6.5 mm screws that surround the fan using the PH1 Phillips screwdriver head.
  4. Samsung NP-N145-JP02US Fan Replacement: Schritt 4, Bild 1 von 1
    • Manually remove the fan from the device by pulling out the connector.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 18
Insgesamt: 622
