Zum Hauptinhalt wechseln
Samsung NP-N145-JP02US Keys Replacement
Was du brauchst
  1. Samsung NP-N145-JP02US Keys Replacement, Keys: Schritt 1, Bild 1 von 1
    • Before starting the replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Keys Replacement: Schritt 2, Bild 1 von 1
    • Open the device with the keyboard and screen showing.
  3. Samsung NP-N145-JP02US Keys Replacement: Schritt 3, Bild 1 von 1
    • Loosen the chosen key by prying all four corners with a plastic opening tool.
    • Push the plastic opening tool under the key and carefully pull upwards until the key comes loose and pops off.
  4. Samsung NP-N145-JP02US Keys Replacement: Schritt 4, Bild 1 von 1
    • Slowly grab the loose key away from the keyboard.
    • Be careful to leave the plastic pieces underneath the key in tact and unmoved. If plastic pieces do get moved, take tweezers and lift them back into place.
Abschluss
Congratulations! You now have a keyboard with fully functional keys!
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 329
