Zum Hauptinhalt wechseln
Samsung NP-N145-JP02US Screen Replacement
Was du brauchst
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: Schritt 4, Bild 1 von 3 Samsung NP-N145-JP02US Screen Replacement: Schritt 4, Bild 2 von 3 Samsung NP-N145-JP02US Screen Replacement: Schritt 4, Bild 3 von 3
    • Using your fingertips, gently pull screen to pop it out of the frame.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 414
