Einleitung
If you encounter issues while connecting to wireless internet connections, replacing your wireless card may enable you to access the internet.
Was du brauchst
Remove the following 14 screws:
Thirteen 5 mm Phillips #1 screws
One 3.5 mm Philips #001 screw
Carefully insert the plastic opening tool in the seam between the lower casing and the chrome bezel.
Slide the opening tool across all sides of the lower case, and lift it up to remove the case and reveal the internal components.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
