Einleitung
Fan will be replaced in order to improve and control overheating that could create malfunctions on the computer system.
Was du brauchst
Locate the external battery on the bottom side of the device.
Locate the tab on the right side of the battery.
Shift the tab to the left.
Locate the tab on the left side of the device's battery.
Push the left tab to the right.
Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
Using two plastic opening tools remove the back plate.
The back plate is now removed exposing all of the hardware components.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
