Einleitung
You will need to remove the back plate of the netbook to access the hard drive. This is easily done by following the back removal guide.
Was du brauchst
Locate the external battery on the bottom side of the device.
Locate the tab on the right side of the battery.
Shift the tab to the left.
Locate the tab on the left side of the device's battery.
Push the left tab to the right.
Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
Using two plastic opening tools remove the back plate.
The back plate is now removed exposing all of the hardware components.
Locate the hard drive.
Remove the one 3.93 mm screw holding the hard drive in place using a PH1 screw bit.
Hold the end of the hard drive farthest from where it is connected to the netbook. Then gently pull in the opposite direction of where the hard drive is connected.
Your hard drive is now removed.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thanks for your kindness.
Where can I get the screws from
