Einleitung
If your computer gets stuck or does not open/close smoothly, it may help to replace the hinges using this guide. The optical drive and hard drive must be removed first.
Was du brauchst
Flip the laptop over.
Remove the 6 mm screw with the Phillips #000 screwdriver.
Flip the laptop.
Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
Gently wedge the spudger under the square panel.
Run the spudger under the edges of the square panel to loosen it.
Remove the panel.
Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
Disconnect the wire from the motherboard by pulling up and away from the laptop.
Remove the top two rubber stoppers using precision tweezers.
Disconnect the wire by carefully using the plastic opening tool to pry the connector away from the motherboard.
Open the laptop slightly.
Holding the laptop open, remove three 4 mm screws from each hinge (6 total) using a Phillips #000 screwdriver.
Hold hinges in place with your thumb and slide the laptop away from the screen.
Wedge the metal spudger underneath the cover and run it along the edges. Gently pry the cover up.
Remove the three 4 mm screws on each hinge with a Phillips #000 screwdriver. There should be a total of 6 screws to remove.
