Zum Hauptinhalt wechseln
Samsung NP-R540-JA09US Front Panel Replacement
Was du brauchst
  1. Samsung NP-R540-JA09US Front Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 2, Bild 1 von 1
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 3, Bild 1 von 2 Samsung NP-R540-JA09US Front Panel Replacement: Schritt 3, Bild 2 von 2
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US Front Panel Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Remove securing screw with the PH0 head.
  5. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 5, Bild 1 von 1
    • Slide the optical drive out and remove it from the device.
  6. Samsung NP-R540-JA09US Front Panel Replacement, Keyboard: Schritt 6, Bild 1 von 1
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 8, Bild 1 von 1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 9, Bild 1 von 2 Samsung NP-R540-JA09US Front Panel Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the keyboard cable from the motherboard.
  9. Samsung NP-R540-JA09US Front Panel Replacement, Front Panel: Schritt 10, Bild 1 von 1
    • Remove the two screws with a Phillips #00 screwdriver.
  10. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 11, Bild 1 von 1
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
  11. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 12, Bild 1 von 3 Samsung NP-R540-JA09US Front Panel Replacement: Schritt 12, Bild 2 von 3 Samsung NP-R540-JA09US Front Panel Replacement: Schritt 12, Bild 3 von 3
    • Pry the front panel away from the base with an Opening Tool.
  12. Samsung NP-R540-JA09US Front Panel Replacement: Schritt 13, Bild 1 von 2 Samsung NP-R540-JA09US Front Panel Replacement: Schritt 13, Bild 2 von 2
    • Disconnect the speaker wire from the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 490
