Einleitung
Is your laptop not loading pages correctly? Consider using this guide to replace the RAM in your laptop.
Was du brauchst
Flip the laptop over so that the bottom of the laptop is facing upwards.
Unscrew and remove the two screws from the back panel labeled "Memory" with a Phillips #0 screwdriver.
Place the flat end of the spudger or your fingers, if possible, between the panel and the laptop. Pry the panel by moving the spudger up and down until the panel can be removed.
Release the two holding pins by pushing them away from each other with your fingers or a spudger.
