Einleitung
This guide will help you replace your fan. You may want to use this guie if your computer's fan stops running.
Was du brauchst
Turn your laptop upside down so that the battery component is facing you.
Place your thumbs on the lock tabs.
Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
Pull the battery out of the laptop towards yourself to safely remove the battery.
Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Insert the plastic opening tool between the seam of the back panel and the laptop.
Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
Unscrew the four 8.9mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the two 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
4 weitere Personen haben diese Anleitung absolviert.
