Zum Hauptinhalt wechseln
Samsung NP305E5A-A03US Optical Drive Replacement
Was du brauchst
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 3, Bild 1 von 2 Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 5, Bild 1 von 2 Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: Schritt 7, Bild 1 von 1
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 8, Bild 1 von 2 Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 8, Bild 2 von 2
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 9, Bild 1 von 3 Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 9, Bild 2 von 3 Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 9, Bild 3 von 3
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 10, Bild 1 von 2 Samsung NP305E5A-A03US Optical Drive Replacement: Schritt 10, Bild 2 von 2
    • Remove the Optical Drive by sliding it away from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kris Stobbe
585 Reputation
3 Anleitungen geschrieben
Baylor, Team 5-7, Williams Fall 2016 Mitglied von Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 315
