Einleitung
This guide will help you replace your malfunctioning optical drive. You may want to use this guide if your CD/DVD drive is unresponsive.
Was du brauchst
Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Insert the plastic opening tool between the seam of the back panel and the laptop.
Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
Eine weitere Person hat diese Anleitung absolviert.
