Einleitung
This is a step-by-step guide of how to remove your RAM in order to replace it.
Was du brauchst
Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
Place your thumbs on the metal tabs.
Push outwards on the metal tabs to release the RAM.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
