Zum Hauptinhalt wechseln
Samsung NP350E5C-A02US RAM Replacement
Was du brauchst
  1. Samsung NP350E5C-A02US RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US RAM Replacement: Schritt 3, Bild 1 von 1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US RAM Replacement, Hard drive and memory stick cover: Schritt 4, Bild 1 von 1
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US RAM Replacement: Schritt 5, Bild 1 von 1
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US RAM Replacement: Schritt 6, Bild 1 von 1
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US RAM Replacement, RAM: Schritt 7, Bild 1 von 1
    • Gently push the lock springs outwards and the RAM stick will rise when it's free.
  8. Samsung NP350E5C-A02US RAM Replacement: Schritt 8, Bild 1 von 1
    • Then, gently pull the RAM stick towards the front of the laptop.
  9. Samsung NP350E5C-A02US RAM Replacement: Schritt 9, Bild 1 von 1
    • Repeat the last two steps for the second RAM stick if needed.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 257
