Einleitung
If you find that your laptop is having connection issues and isn't resolved after the given steps on the troubleshooting page, then replace the Wifi card.
Was du brauchst
Using a Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
