Einleitung
This guide helps users to replace the CD Drive successfully by following these easy steps.
Was du brauchst
Flip the laptop over so that the bottom is facing toward you.
Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
