Einleitung
This guide helps users to replace the ODD/HDD/Memory Cover successfully by following these easy steps.
Was du brauchst
Flip the laptop over so that the bottom is facing toward you.
Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
2 weitere Personen haben diese Anleitung absolviert.
