Einleitung
This guide will demonstrate the process of replacing one of the keys on the keyboard.
Was du brauchst
Turn the computer off.
Disconnect the charging cable from the laptop.
Flip the laptop face down on a flat surface.
While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
Place the inner retainer piece into the outer retainer piece by inserting the posts into the grooves on the outer retainer piece.
Use angled tweezers to place the assembled retainer onto the two (2) metal brackets on the keyboard.
Once the retainer is attached, press the key onto the retainer, it will make a snapping sound when in place.
