Einleitung
We are going to teach users how to replace the RAM chips.
Was du brauchst
Turn the computer off.
Disconnect the charging cable from the laptop.
Flip the laptop face down on a flat surface.
While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
Locate the ODD/HDD/Memory panel.
Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
Slide the ODD/HDD/Memory panel away from the device to remove it.
Locate the two (2) metal brackets holding the RAM chip in place.
Carefully push the brackets outwards away from the RAM chip, causing it to pop out of the brackets.
Remove the first RAM chip by pulling it up and out of its plug.
Locate the second set of metal brackets holding the remaining RAM chip.
Remove the second RAM chip by pulling it up and out of its plug.
