Zum Hauptinhalt wechseln
Samsung NP36535C-S05US RAM Replacement
Was du brauchst
  1. Samsung NP36535C-S05US RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US RAM Replacement: Schritt 3, Bild 1 von 2 Samsung NP36535C-S05US RAM Replacement: Schritt 3, Bild 2 von 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US RAM Replacement, ODD/HDD/Memory panel: Schritt 4, Bild 1 von 3 Samsung NP36535C-S05US RAM Replacement, ODD/HDD/Memory panel: Schritt 4, Bild 2 von 3 Samsung NP36535C-S05US RAM Replacement, ODD/HDD/Memory panel: Schritt 4, Bild 3 von 3
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
  5. Samsung NP36535C-S05US RAM Replacement, RAM: Schritt 5, Bild 1 von 2 Samsung NP36535C-S05US RAM Replacement, RAM: Schritt 5, Bild 2 von 2
    • Locate the two (2) RAM chips in the upper left corner.
  6. Samsung NP36535C-S05US RAM Replacement: Schritt 6, Bild 1 von 3 Samsung NP36535C-S05US RAM Replacement: Schritt 6, Bild 2 von 3 Samsung NP36535C-S05US RAM Replacement: Schritt 6, Bild 3 von 3
    • Locate the two (2) metal brackets holding the RAM chip in place.
    • Carefully push the brackets outwards away from the RAM chip, causing it to pop out of the brackets.
    • Remove the first RAM chip by pulling it up and out of its plug.
  7. Samsung NP36535C-S05US RAM Replacement: Schritt 7, Bild 1 von 3 Samsung NP36535C-S05US RAM Replacement: Schritt 7, Bild 2 von 3 Samsung NP36535C-S05US RAM Replacement: Schritt 7, Bild 3 von 3
    • Locate the second set of metal brackets holding the remaining RAM chip.
    • Remove the second RAM chip by pulling it up and out of its plug.
  8. Samsung NP36535C-S05US RAM Replacement: Schritt 8, Bild 1 von 1
    • You have successfully removed the RAM chips.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 316
