Einleitung
The display for a device gives visual output for the user to interact with. This guide will help you replace it properly.
Was du brauchst
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
Unscrew the two 4.45mm long screws to disconnect the left hinge.
Unscrew the two 4.45mm long screws to disconnect the right hinge.
Using the plastic opening tool, pry open the plastic housing that holds the display.
