Einleitung
The hard drive stores crucial memory for a device. This guide will show you how to replace it properly.
Was du brauchst
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
Fast fertig!
Abschluss
