Einleitung
Random Access Memory (RAM) is a critical part of any device, it assists the device to run smoothly. This guide will show you how to replace it properly.
Was du brauchst
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Press down on the tabs on both sides of the RAM to release, then pull away from the mount to remove.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
