Zum Hauptinhalt wechseln
Samsung NP540U3C-A02UB Battery Replacement
Was du brauchst
  1. Samsung NP540U3C-A02UB Battery Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Battery Replacement: Schritt 2, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Battery Replacement: Schritt 3, Bild 1 von 3 Samsung NP540U3C-A02UB Battery Replacement: Schritt 3, Bild 2 von 3 Samsung NP540U3C-A02UB Battery Replacement: Schritt 3, Bild 3 von 3
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Battery Replacement: Schritt 4, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Battery Replacement: Schritt 5, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Battery Replacement: Schritt 6, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Battery Replacement, Battery: Schritt 7, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement, Battery: Schritt 7, Bild 2 von 2
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Battery Replacement: Schritt 8, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 8, Bild 2 von 2
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Battery Replacement: Schritt 9, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 9, Bild 2 von 2
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Battery Replacement: Schritt 10, Bild 1 von 1
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Battery Replacement: Schritt 11, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 11, Bild 2 von 2
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Battery Replacement: Schritt 12, Bild 1 von 3 Samsung NP540U3C-A02UB Battery Replacement: Schritt 12, Bild 2 von 3 Samsung NP540U3C-A02UB Battery Replacement: Schritt 12, Bild 3 von 3
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Battery Replacement: Schritt 13, Bild 1 von 2 Samsung NP540U3C-A02UB Battery Replacement: Schritt 13, Bild 2 von 2
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Battery Replacement: Schritt 14, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alejandro
253 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team C-1, Gurgel Spring 2022 Mitglied von UMass Dartmouth, Team C-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SCG1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 37
Insgesamt: 908
