Einleitung
This guide will help a user to remove their device's broken or cracked screen using the steps below.
Was du brauchst
Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
Wedge your fingers in between the upper case and the lower case
Gently pull the lower case away from the upper case to remove it
Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
Place your fingers on the corner sections of the battery.
Lift to remove the battery.
Place the tip of the spudger under the metal caps of the black and grey coaxial connectors and pry upwards to disconnect them.
After they are disconnected, un-thread the coaxial connectors from around the fan.
Using the Phillips#00, remove the single 3.5mm screw from the wireless card.
Grasp the edges of the wireless card with your fingers and pull straight backwards to remove it.
Using the Phillips#00, remove the six 4.5mm screws from the corner brackets holding the display to the inner case.
Using your fingers, grasp the edges of the inner case then lift and pull away to separate it from the display.
