Einleitung
This guide will provide detailed steps to replace the hard drive in the Samsung device.
Was du brauchst
Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
Wedge your fingers in between the upper case and the lower case
Gently pull the lower case away from the upper case to remove it
Place your fingers on the corner sections of the battery.
Lift to remove the battery.
Using the tip of the spudger, flip up the small locking flap on the ZIF connector. Now you can pull the cable.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thanks, Eric. I wished I’d read your ifixit lesson before I broke it!! Next time I’ll know better.
