Einleitung
This guide is designed to help remove and replace the ram card in the Samsung NP700Z5AH.
Was du brauchst
Using the Phillips #00 screwdriver, remove the 6.6mm screw from the memory slot cover.
Wedge your finger underneath the edge of the memory cover. Grasp and pull the cover to the left to remove it.
Using the tweezers, push the edges of the metal clasps holding the ram card away from the card. You should see the card pop upwards.
Eine weitere Person hat diese Anleitung absolviert.
