Einleitung
The Wifi Card in your laptop is a necessary component in order to access online features that a computer included. If your card is damaged or broken it will need to be removed for it to be replaced or repaired.
Was du brauchst
This guide should be attempted after the removal of the back panel is completed.
The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
In order to continue, you need to observe the inside of the laptop and find where the Wifi Card is located.
After finding the Wifi Card, you will discover two more 2.5mm Phillips #00 screws which hold the card in place.
The screws locations are shown in the image.
The same bit piece will be used to unscrew these (PH00/PH000). After completing this continue to the next step.
There will be two wires connecting to the Wifi Card from the laptop.
These wires can be removed with one of the plastic tools in the iFixit toolkit by applying slight force onto them.
After removing the wires move on to the next step.
This last step is the easiest of them all, all you need to do it pick up the Wifi Card from its position and you're done!
Now you are able to replace the card by following these steps in reverse or have the card further repaired.
