Einleitung
This guide will show you how to separate the back panel from the camera. Before starting the guide make sure the camera is powered off and the memory card is removed.
Was du brauchst
Locate the bottom panel of the camera.
Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
Open the two halves of the camera, taking care not to disturb the ribbon cable.
Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
Push the ribbon out of its socket with the plastic opening tool.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
