Einleitung
If you need to replacement your front lens, here is the guide to do so. Be sure to turn off your camera and take out the battery before you being your replacement.
Was du brauchst
Unscrew the four 5.5 mm #000 Philips screws that are on the metal ring with a Philips #000 screwdriver.
Remove the three 4.5 mm Phillips #000 head screws located inside the cover with a Phillips #000 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
