Zum Hauptinhalt wechseln
Samsung NX2000 LCD Replacement
Was du brauchst
    1. Samsung NX2000 LCD Replacement, LCD: Schritt 1, Bild 1 von 1
      • First begin by flipping your camera upside down.
      • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
      • Remember to store the screws in a secure place.
      Frag FixBot
      Kommentar hinzufügen
    2. Samsung NX2000 LCD Replacement: Schritt 2, Bild 1 von 3 Samsung NX2000 LCD Replacement: Schritt 2, Bild 2 von 3 Samsung NX2000 LCD Replacement: Schritt 2, Bild 3 von 3
      • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Frag FixBot
    3. Samsung NX2000 LCD Replacement: Schritt 3, Bild 1 von 3 Samsung NX2000 LCD Replacement: Schritt 3, Bild 2 von 3 Samsung NX2000 LCD Replacement: Schritt 3, Bild 3 von 3
      • Before taking it apart you'll have to detach the display ribbon cable.
      • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
      Frag FixBot
    4. Samsung NX2000 LCD Replacement: Schritt 4, Bild 1 von 3 Samsung NX2000 LCD Replacement: Schritt 4, Bild 2 von 3 Samsung NX2000 LCD Replacement: Schritt 4, Bild 3 von 3
      • Separate the LCD half compartment of the camera from the main body.
      Frag FixBot
    5. Samsung NX2000 LCD Replacement: Schritt 5, Bild 1 von 1
      • Remove the four 1mm screws with the Y0 screwdriver.
      Frag FixBot
    6. Samsung NX2000 LCD Replacement: Schritt 6, Bild 1 von 3 Samsung NX2000 LCD Replacement: Schritt 6, Bild 2 von 3 Samsung NX2000 LCD Replacement: Schritt 6, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
      • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      Frag FixBot
    7. Samsung NX2000 LCD Replacement: Schritt 7, Bild 1 von 3 Samsung NX2000 LCD Replacement: Schritt 7, Bild 2 von 3 Samsung NX2000 LCD Replacement: Schritt 7, Bild 3 von 3
      • Place blue plastic spudger in between LCD screen and plastic surrounding.
      • Begin to lift up slowly, removing the LCD screen from the main frame.
      Frag FixBot
    8. Samsung NX2000 LCD Replacement: Schritt 8, Bild 1 von 1
      • The LCD screen is now separated form the main frame.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 7-4, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 33
Insgesamt: 1,396
