Zum Hauptinhalt wechseln
Samsung NX2000 Lens Assembly Replacement
Was du brauchst
  1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: Schritt 1, Bild 1 von 2 Samsung NX2000 Lens Assembly Replacement, Lens Assembly: Schritt 1, Bild 2 von 2
    • Begin by pressing the lens lock button to the right of the lens.
    • Release the button and turn the lens in a clockwise motion until you have removed the lens.
    Frag FixBot
  2. Samsung NX2000 Lens Assembly Replacement: Schritt 2, Bild 1 von 3 Samsung NX2000 Lens Assembly Replacement: Schritt 2, Bild 2 von 3 Samsung NX2000 Lens Assembly Replacement: Schritt 2, Bild 3 von 3
    • Make sure your camera is turned off and flip your device upside down.
    • Slide the battery switch to the left and open the battery compartment.
    • Push the blue button up inside the battery compartment and remove the battery.
    Frag FixBot
  3. Samsung NX2000 Lens Assembly Replacement: Schritt 3, Bild 1 von 3 Samsung NX2000 Lens Assembly Replacement: Schritt 3, Bild 2 von 3 Samsung NX2000 Lens Assembly Replacement: Schritt 3, Bild 3 von 3
    • Remove the four 4mm screws highlighted here with the Y0 screwdriver.
    • Using a tweezer, gently remove the outer silver lens lining.
    • Underneath will lie a black ring, which needs to removed using the same tweezer.
    Frag FixBot
  4. Samsung NX2000 Lens Assembly Replacement: Schritt 4, Bild 1 von 3 Samsung NX2000 Lens Assembly Replacement: Schritt 4, Bild 2 von 3 Samsung NX2000 Lens Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove the final silver ring from the lens assembly using a tweezer.
    • Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
    • Remove the spring from the same compartment using the same tool.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 7-4, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 59
Insgesamt: 1,314
