Zum Hauptinhalt wechseln
Samsung NX2000 Motherboard Replacement
Was du brauchst
  1. Samsung NX2000 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Samsung NX2000 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Samsung NX2000 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the 4mm Y0 screws found on the sides and bottom of the camera.
  2. Samsung NX2000 Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung NX2000 Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung NX2000 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to pry the back cover (with LCD screen) away from the front of the camera.
    • Use a plastic opening tool to disconnect the LCD ribbon cable holding the two pieces of the camera together.
  3. Samsung NX2000 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Move towards the main frame of the camera and locate the three 1mm Y0 screws holding down the motherboard.
  4. Samsung NX2000 Motherboard Replacement: Schritt 4, Bild 1 von 2 Samsung NX2000 Motherboard Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Lift the duct tape covering the ribbon cable connectors.
    • Use a plastic opening tool to lift the black tab on top of the ZIF connectors.
    • Pull all five ribbon cables out with tweezers.
  5. Samsung NX2000 Motherboard Replacement: Schritt 5, Bild 1 von 3 Samsung NX2000 Motherboard Replacement: Schritt 5, Bild 2 von 3 Samsung NX2000 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Take the time to make sure everything is detached and lift the motherboard slowly using your fingers.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 7-4, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare zur Anleitung
The step for removing the metal hot shoe lit and removing 2 small screws is missing.
This is also required in order to be able to remove the back cover.
Rinaldo Eversdijk - Antwort
The step removing the metal hot shoe lit and removing 2 small screws underneath is missing.
This is required in order to be able to remove the back cover.
The camera is simply dead from one day to the next it stopped working, what could it be?
my_legacy_lethal_infected - Antwort
Aqui a mesma coisa, do nada, quando liga a câmera o LED Verde fica parado e em seguida pisca alternadamente, ESTÁ NOVISSIMA, nunca sofreu quedas ou qualquer outro tipo de avaria
Gabriel Fernandes Guimaraes -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 39
Insgesamt: 1,852
