Einleitung
If your laptop only powers on when the power adapter is plugged in, you may have a faulty battery and it needs to be replaced. Signs of a faulty battery can include: device isn’t charging, device won’t hold a charge, device won’t turn on, etc.
This is a battery replacement guide for the Samsung Notebook 7 Spin NP740U3MK01US. Before beginning, make sure to power off your device and disconnect it from any external power source.
Was du brauchst
Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
6 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
This is a great guide. Where do I purchase the battery from as I’m not finding it on this website?
