Zum Hauptinhalt wechseln
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
Was du brauchst
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 2, Bild 1 von 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 3, Bild 1 von 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 4, Bild 1 von 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 5, Bild 1 von 3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 5, Bild 2 von 3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 5, Bild 3 von 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: Schritt 6, Bild 1 von 1
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: Schritt 8, Bild 1 von 1
    • Pull the hard drive away from the cradle and remove it from the device.
Abschluss
2 Kommentare
Would you point out where the SSD slot would be?
aroyphillips - Antwort
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 54
Insgesamt: 3,330
