Einleitung
When your laptop is dropped from an elevated surface, there’s a very good chance the screen will be damaged. You may notice that your screen is cracked or unresponsive to touch. You may also notice a few dead pixels on your screen and that the color may be a little off.
This is a replacement guide for the touch screen of the Samsung Notebook 7 Spin. If your touch screen is unresponsive or is cracked, it needs to be replaced.
Was du brauchst
Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
Remove the connections for the screen using a pair of tweezers or your fingers.
Remove the four 4.5mm screws using a Phillips #00 screwdriver that connect the top and bottom of the computer through the hinge.
Gently remove the screen guard on the front end using the plastic opening tool.
Heat the iFixit iOpener in the microwave for 30-45 seconds and apply it to the edges of the screen to loosen the adhesive.
Once enough heat has been applied, use the plastic opening tool and the metal spudger to separate the screen from the backing.
Use the suction cup to raise the screen backing with care. Do not remove the screen from the device yet as there are cables connected along the bottom.
2 weitere Personen haben diese Anleitung absolviert.
