Zum Hauptinhalt wechseln
Samsung Odyssey NP800G5M Battery Replacement
Was du brauchst
  1. Samsung Odyssey NP800G5M Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Battery Replacement: Schritt 2, Bild 1 von 2 Samsung Odyssey NP800G5M Battery Replacement: Schritt 2, Bild 2 von 2
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Odyssey NP800G5M Battery Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Battery Replacement: Schritt 4, Bild 1 von 3 Samsung Odyssey NP800G5M Battery Replacement: Schritt 4, Bild 2 von 3 Samsung Odyssey NP800G5M Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 1,888
