Einleitung
If your Samsung Odyssey NP800G5M is not powering on or charging, it is most likely due to a faulty/dead battery. The battery can be replaced in a few simple steps. However, take the necessary precautions.
Was du brauchst
Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
Work your way around the body of the laptop until the back cover is completely separated.
Remove the back casing.
Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
Remove the battery from the device.
5 weitere Personen haben diese Anleitung absolviert.
